05' kodiak 450 shifting problem
Old Feb 20, 2009 | 10:32 PM
ekimessej's Avatar
Default 05' kodiak 450 shifting problem
My atv usually starts just fine, but my shift indicator lights don't all come on. I can hardly ever get the park light to come on. Because of this, I usually have to start it while in neutral. Is there a fix for this? Thanks in advance!
Old Feb 21, 2009 | 10:35 AM
450kodman's Avatar
my 03 did this occasionally, when i shifted it, if i moved the shifter as far left as it could go and went through the gears, the lights would work again. see if that makes a difference, if not its probably a good idea to take it to the dealer.
Old Feb 21, 2009 | 01:55 PM
HeftyLefty's Avatar
Don't waste money at the dealer for something you can fix yourself if you are mechanically knowledgeable. You just need to adjust your linkage. To do that.
1. Disconnect linkage at transmission shifter.
2. Turn key ON with killswitch OFF, move transmission shifter fork till Neutral light shows on display. Verify Neutral by gently rolling quad back and forth. Turn key OFF.
3. Move Shift selector **** to Neutral.
4. Adjust linkage to take up slack. Reconnect.
5.Start quad, make sure shifter **** selects all gears without grinding, fine tune as necessary. Turn quad OFF before making any adjustments.
6. Lube linkage with good waterproof grease.
People who have done it says it takes about an hour.
Old Feb 21, 2009 | 05:35 PM
Wildman89's Avatar
Thats good to know heftyLefty, thanks!
I've got a 07 Grizz 450 and it started doing that back before hunting season.
Now i know how to fox it. Thanks again.
Old Feb 21, 2009 | 11:32 PM
ekimessej's Avatar
Thanks for the info! I'll do this the first chance I get. Thanks again!!!
lightninboy
May 16, 2021 09:52 PM
RedRancher
Oct 15, 2020 01:45 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
