grizzly 660 A-arm problem
Old Feb 22, 2009 | 09:35 PM
Jbridered's Avatar
Default grizzly 660 A-arm problem
While riding today my upper and lower a-arm came off. The upper a-arm pulled out from the bottom side exposing the ball and left the boot and flat round metal portion still on the upper a-arm. I looked on partsfish and other sites for the upper ball joint and they only show the castle nut for the upper a-arm. Can the upper ball joint be changed without buying a new a arm? This seems like it could possibly be dangerous. I just replaced the lower front ball joint along with a new nut and bolt and it still came out. Can anyone tell me the best way to fix the lower clamp so that it wont just slip out. Thanks
Old Feb 23, 2009 | 01:56 AM
Malachi's Avatar
Mine has come loose once but I was able to torque it back down.
If the clamp for the lower ball joint isn't holding anymore, you may have to replace the whole spindle since the clamp is part of it.
The upper ball joint is replaced as a unit with the upper A-arm. I don't believe you can change just the upper ball joint.
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
hondarider1234
Jul 21, 2015 11:53 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
musselmark
Jul 17, 2015 02:40 PM
