2005 yamaha kodiak 450 problem with rearend gears
Old Jan 25, 2007 | 09:12 PM
K22's Avatar
K22
Default 2005 yamaha kodiak 450 problem with rearend gears
My rearend gears completely went out on my kodiak 450 and I was wondering if anyone else has had the same problem. I'm sure glad I had a warranty, the bill was $1,000. If anyone has had any other problems would you please let me know. Thank you
Old Jan 25, 2007 | 09:17 PM
squeege's Avatar
HUH???
More Info please!
Old Jan 25, 2007 | 09:21 PM
K22's Avatar
K22
Well, I was out riding one day and I noticed that when I put the thing in reverse the gears were grinding. It didn't do it in high or low just reverse, so I took it to the mechanic and he said he had to replace all the gears in the rearend. He said that one of the gears broke and scared up all the other gears. He told me he had never seen one do that, so I was just doing some checking around.
Old Jan 25, 2007 | 10:27 PM
u1arunit's Avatar
Was the fluid level very low? When I did my first service there was only about 1-2 oz of fluid in there. Glad I changed it. I will never depend on the dealer to check the levels when the vehicle is readied for delivery. Mine has like 90 miles or so on it and I assumed the dealer would have checked..
Old Jan 26, 2007 | 07:54 AM
K22's Avatar
K22
Well, I never did check the fluid. I let the mechanic do it just like you said. I guess I will start checking my own stuff now too. The mechanic never said that it was low on fluid when he tore it apart.
Old Jan 26, 2007 | 06:57 PM
Neurodog's Avatar
I have the same ATV and had to replace my rear end last month. Last summer I hit a log and didn't notice that it had damaged a seal and all the oil drained and my rear end seized. The garage told me that it would cost me $1500 (Canadian dollars) but I was able to buy it online and performed the repair on my own for about $750.
Who know's what happened to yours but I don't think it's wide spread.
Old Jan 27, 2007 | 02:41 AM
rruser's Avatar
If you have a solid rear axel, bad axel bearings can also cause rear-end problems over the long run. I have only seen it once before though.
Old Feb 23, 2009 | 08:42 AM
yamikodiak07's Avatar
Do you plow snow with it?? alot of people plow snow with atvs, this is very hard on the little frame and gearing.I no alot of people who tried and paid somtimes more then you.
MrElussive
Oct 26, 2000 02:30 PM
MrElussive
Oct 19, 2000 09:50 PM
hammer4
Sep 14, 2000 07:43 PM
hammer4
Sep 13, 2000 12:52 PM
aby11
May 7, 2000 07:58 PM
