polaris 500
Old Feb 24, 2009 | 04:25 PM
bigter's Avatar
Default polaris 500
ok Im know I have to change camshaft not sure what side of motor it comes out of.I belive the valves are set to .006 it this right its a 1996 polaris 500 sportmans.Do I have to worry about the timing chain guiges coming together should i block them open?If anyone has manual on this it would help a lot thanks. sorry for double post please remove one.
Old Feb 24, 2009 | 04:39 PM
Default polaris 500
Cam removes from left side,jusr remove plate. Guides will stay where they are. Remove rocker arms and shafts,remove 3 bolts on cam sprocket ,pull chain and sprocket combo away from cam,and remove cam,sprocket and chain will just go down a little,but will stay in head. EASIER if you have cam index pin CENTER TOP of head before you remove sprocket,easier to retime.
Old Feb 24, 2009 | 05:06 PM
bigter's Avatar
Default polaris 500
so just to be sure your talking about right side if your sitting on quad am I right about the vavles at .006 thanks for the help
Old Feb 25, 2009 | 07:33 AM
Kerbbirds's Avatar
Default polaris 500
Left side as your on the Quad.
Old Feb 25, 2009 | 10:14 AM
Rutcutter's Avatar
Default polaris 500
Im about to check mine out also,is .006 where the valve clearance needs to be?
Old Feb 25, 2009 | 05:23 PM
bigter's Avatar
Default polaris 500
so one more time not that I'm slow or anything lol if I'm on the quad I take the camshaft out the left side so I will have to take the water ports off that side not just plates and the vavles set to 006 thanks
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
