giant front wheel
Old Feb 24, 2009 | 08:35 PM
loadder's Avatar
Default giant front wheel
in my pics i have a green camo 3 wheeler, does anyone know where i can get a 2nd front wheel and tire for that, or what model it is even, i know nothing about it, think it is an 1983 200 ??? a little help please
Old Mar 5, 2009 | 05:47 PM
SMFREY's Avatar
The front end is exactly like my 82 185S
The fuel tank is an aftermarket Clark same as my 185s
The rest looks like aftermarket for hunting keep mud from flying up
If you are looking for one of those front ends I have a parts 185
Good luck
Ray
Old Mar 5, 2009 | 07:02 PM
loadder's Avatar
do you have the front wheel and tire ?
Old Mar 6, 2009 | 05:38 PM
SMFREY's Avatar
I do have the fork and wheel assembly with brakes with wheel
Tire BAD
Tires easy to find
I have clean split rims as they are same as on my 110s have pile since went with Aluminum on 110s
These are just the 4 bolt split rims with O-Ring seal
Tires are 22-11-8
Ray
Old Mar 7, 2009 | 11:55 AM
odysseyjunk's Avatar
ive been looking all over to try to find a front replacement rim for mine, but it seems that you just cannot get 4x130mm bolt pattern with center offset......im sad man..... everything else at least its possible to get without fabricating!!! i guess im going to make an adapter plate so i can mount a 4x110 wheel, ill keep you guys updated on it, and if it works, it will be cheap, since im making it out of 1/4inch steel!
Old Mar 9, 2009 | 06:10 PM
SMFREY's Avatar
I noticed this weekend
I along with having several sets of split rims
I also seem to have 3 welded rims from a 200S
I will relook tonight when I get home
No need for them since I have gone with Aluminum
Thanks
Ray
TLC
Jul 25, 2015 02:24 AM
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
tporath
Jul 11, 2015 12:31 PM
