Warn or Champion winch?
Old Feb 26, 2009 | 12:39 PM
7shortmag's Avatar
Default Warn or Champion winch?
I have a Warn 2500 ci winch and a Champion 2000lb winch.
The Warn had some health issues that have been resolved.
The Champion is now on my machine, which is an Outlander 800.
Which winch is better?
I want to put the Warn back on the machine just because of the name.
Are Champion winches any good?
Thanks!
Old Feb 27, 2009 | 10:13 AM
TLC's Avatar
TLC
If it work it works just leave the campion on. I would just keep one or the other as a spare.
My warn 2500 ci just stopped working also, how did you fix yours?
atvman29's Avatar
Can't say I've ever heard of champion winches.
Old Feb 27, 2009 | 10:33 AM
TLC's Avatar
TLC
This Polaris 500 Scrambler we ride with has a 2000 Champion winch,seems to do the job when called upon.
Old Feb 27, 2009 | 11:15 AM
7shortmag's Avatar
Took it apart and started looking around. There is a plastic bushing on each end of the drum. The cable got between the drum and the housing and chewed the bushing up. There was a piece of the bushing lodged between a set of the planetary gears. Cleaned it up and it works well now. Warn also gave me new bushings for free.
If I were you, I would take it apart and try the motor with a 12V power source. If the motor works in both directions it is worth fixing. If the motor is toast, maybe not. The motor is $150.00
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
Alex G.
Sep 19, 2015 06:34 PM
