New question bout cluth and belt housing?
Old Feb 26, 2009 | 10:17 PM
dieselrob's Avatar
Default New question bout cluth and belt housing?
Im gonna start fixing things befor nice riding weather gets here. Ive been having problems with water gettin in the clutch housing while in deep puddle and the belt will start slipping till it dries out a bit. I can grab the case and kinda wiggle it a little bit, mabey 1/4 inch of play. I dont know if it flexible since its plastic or if its loose or cracked where it meets the crank case. Im hoping i just have a bad seal on the outer cover. But has anyone had any problems with there case where it mounts to the engine leaking?
Old Feb 27, 2009 | 12:19 AM
eggenz7's Avatar
there is also a seal behind the drive clutch. it can get eat up if a motor mount is out of alignment and will let lot of water in
Old Feb 27, 2009 | 07:09 AM
dieselrob's Avatar
Im gonna tear it apart today and see whats up. Ill try the trick with filling it up and seeing where it leaks out.
Old Feb 27, 2009 | 10:47 AM
dieselrob's Avatar
Found my leak. Unfortunately its the seal from the cover to the crankcase. How do you guys get the drive clutch off with out the fancy polaris clutch puller (probly cost an arm or 2)? Any home remedies or does local auto stor have something that works?
Old Feb 27, 2009 | 02:01 PM
teamplayer's Avatar
get yourself a 9" long piece of 3/4" <u>fine</u> thread rod and some nuts. You can make a puller out of it.
Old Feb 27, 2009 | 02:46 PM
dieselrob's Avatar
So its a standard right hand fine thread then? I was thinking about a bolt and welding a piece of 1/2in steel rod to it.
Old Feb 27, 2009 | 03:14 PM
teamplayer's Avatar
Yes it a standard right hand FINE thread. Don't put a 1/2" rod on the end of it. You want the 3/4" to push on the end of the crank it-self not on the small threads in the crank. I used a 3/4" nut on the end and welded it to use a wrench to turn it. You may be able to use two nuts together instead of welding it. NOTE: when it comes time to put the clutch back on, be very sure that you torque the center bolt to spec. if you over tighten it, you may not get it off again, ever.
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
toonces
Aug 5, 2015 05:55 PM
