How do you know when a rear shock needs replaced or rebuilt
Old Feb 27, 2009 | 12:02 PM
tyanna's Avatar
Default How do you know when a rear shock needs replaced or rebuilt
It's a 2001 Polaris Scrambler 500 with a Fox shock. When I sit down on it (I'm only 100 lbs) the rear end squats pretty low. We are trying to figure out how to know if it needs rebuilt or if it just needs to be adjusted. When you sit on it it sounds like it's letting air out.. What do yall think?
Old Feb 27, 2009 | 01:49 PM
Big600twin's Avatar
Not sure if that machine is like a sportsman but I would think it would be the spring. The shock doesn't provide "lift" the spring is normally what helps hold the machine ride height.
Old Feb 27, 2009 | 02:48 PM
tyanna's Avatar
Sooo.. does the spring need adjusted?
Old Feb 27, 2009 | 06:54 PM
plumbob's Avatar
Take the shock off the quad and use a spring compressor to take the spring off of the shock.Compress the shock all the way down and if makes bubbly sounds as it comes back out then the oil has mixed with gas and needs to be rebuilt.From my experience with sleds gas shocks need a rebuild every 2 years.
Old Feb 27, 2009 | 07:16 PM
tyanna's Avatar
Great! I appreciate the information and will pass it along to my husband.
rcappie4
Jul 10, 2015 04:54 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Coryco
Jul 6, 2015 07:30 PM
Jkfx400P
Jul 6, 2015 10:04 AM
