2005 ac wont start replaced alot
Old Feb 27, 2009 | 03:58 PM
MeMysef's Avatar
Default 2005 ac wont start replaced alot
Hello I have a 2005 AC 4x4 400 and it wont start. Turn the key and the solenoid clicks once. The engine does not crank. . I replaced the battery, replaced the solenoid, replaced the relays, replaced the diodes, pulled the starter off and checked it, it turned fine when hooked up to a battery. No blown fuses. Lights work and gauges work, light up fine. Now Im at a stand still. Any help would be appreciated.
Old Feb 27, 2009 | 04:08 PM
rockout's Avatar
cables?
Old Feb 27, 2009 | 06:00 PM
swampyjunior's Avatar
Does it pull start?
I have had engines that guys claim the starter is out and go to replace it and other stuff just to find out the cylinder is full of gas/water etc. so pull the spark plug and take a look.
If it turns over but won't firs then it s an electrical issue. THen you need to start checking the rest of the wiring harness for a shorted out wire or an unplugged connection. Most of my connections that come unplugged are at the base of the steering column.
SJ
neilbedwell
Nov 10, 2018 11:02 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Land_shark1
Jul 10, 2015 12:53 AM
sticky123
Jun 14, 2015 07:36 AM
1000gade
May 27, 2015 12:37 PM
