99 warrior
Old Mar 1, 2009 | 12:30 PM
mwillems85's Avatar
Default 99 warrior
I just bought a 99 warrior for $700. The gut said it dont run, but it did run. I got it home changed the oil, oil filter,plug,cleaned the carb. But when i hit the start button it makes a knocking noise. After a about 4 revolutions it fires, and i let of the start button it runs fine. But then when i go to shut it off it knocks one time. I have a little idea about 4 wheelers but does that sound like the flywheel clutch or not. Let me know what you think it is Thanks guys
Old Mar 1, 2009 | 08:37 PM
beefy46172's Avatar
Loves To Ride!
Default 99 warrior
Sounds like the starter clutch to me.
free2blaze's Avatar
Default 99 warrior
knocking while turning over im not sure, but I recently bought a 93 warrior and when I shut mine off it makes one knock, I asked on here about it and was told it is normal with the warrior, mine runs fine, it is stock,and hauling *** around the trails behind my house it runs great, good luck and let us know what you find out.
Old Mar 1, 2009 | 08:55 PM
91Warrior357's Avatar
Default 99 warrior
yea that noise is the one way starter clutch almost all warriors make that sound when you shut it off, it just sounds like you have maybe a worn starter and a worn one way starter clutch.
Old Mar 14, 2009 | 02:07 PM
mwillems85's Avatar
Default 99 warrior
well i got the starter tore apart and the bushing on the end cap is bad and i had a bushing made. get it back on monday hopefully that is the problem the armichure or however you spell that tested just fine.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
