1993 sportsman not charging HELP
Old Mar 3, 2009 | 04:30 PM
kaptn12's Avatar
Default 1993 sportsman not charging HELP
yes, i have replaced the battery thinking it was a bad battery but that was not it. The bike cranks fine and everything works fine on it, but after riding for a while the electric start wont work the lights dim out. What is causing this prbolem could it be the stator if so how can i tell. Thanks
Old Mar 3, 2009 | 09:17 PM
EARLY Sportsman! I would check reg/rectifier under front panel, usually the problem! Could be wire unplugged or module bad,should charge about 14 volts above idle at battery if everything good!
Old Mar 3, 2009 | 09:51 PM
kaptn12's Avatar
ok i hooked up a voltmeter to it and its reads at 13v when i turn the lights on the voltage starts to drop. i took the front panel off and looked on the drivers side but i cant seem to find the reg/rectifier. Could you tell me what wires im looking for.
Old Mar 6, 2009 | 12:58 AM
kaptn12's Avatar
ok i have found the regulator all the wires were hooke up and i clean the connections stil doesnt keep a charge should i maybe consider changing the regulator or ?
Old Mar 6, 2009 | 07:05 AM
Kerbbirds's Avatar
My bet is the reg, the one on my 425 went bad several years ago, replaced it and no more problems, have also changed them on a couple of other older bikes.
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
Karas3434
Aug 3, 2015 09:17 AM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
