honda mechanic help
Old Mar 4, 2009 | 04:18 PM
skitz80's Avatar
Default honda mechanic help
my atv will not go in reverse the cable works when engaged but under neath the atv there is the spot where the cable connects to a bolt i was wondeing if this is a adjustment or something else and how do i get it to engage into reverse? thanx
Old Mar 4, 2009 | 05:37 PM
HondaMechanic's Avatar
Are you sure the cable is adjusted right .. Here is the adjustment for the cable as you can see it is the same on TRX450 & 500 Foreman ...
This is all there is under the rear of the TRX450 & 500 for the reverse lock-out
Old Mar 4, 2009 | 05:54 PM
skitz80's Avatar
i appreciate the pics but the part i am having trouble with is the arm that mounts to the crankcase and the positioning of the arm is it supposed to be like the pic or straight up and down the pics shows but the words about that are all blocked from view
Old Mar 4, 2009 | 10:29 PM
skitz80's Avatar
greg74
Sep 10, 2019 03:03 PM
Aug 5, 2015 02:10 AM
DeFox500
Jul 26, 2015 06:32 PM
Jul 22, 2015 05:00 AM
CRamshaw777
Jul 18, 2015 05:46 PM
