1988 Blaster Wire Diagram
Old Mar 8, 2009 | 04:34 PM
Mpro420o's Avatar
Default 1988 Blaster Wire Diagram
Im looking for a wire diagram for an 1988 blaster to find out if my wiring is correct also does anyone know if a 2000 cdi box and control box will work on my 88 thank you
Old Mar 8, 2009 | 06:31 PM
91Warrior357's Avatar
yea the cdi should work, part numbers are the same, i think almost everything will swap on all year blasters except for the 02 above headlight and front plastic around the headlight and the newer blasters also had updated front brakes, rest is all the same i believe, see if this little diagram helps.
http://www.bikebandit.com/hous...r-yfs200u-1988/o/m6999
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
Chocobamofo
Jul 10, 2015 07:46 PM
tweeder
Jul 5, 2015 01:57 PM
