2004 rincon 250 need major help plzzz
Old Mar 9, 2009 | 12:25 PM
tommyramone55's Avatar
Default 2004 rincon 250 need major help plzzz
ok, so this post might be a little lenghty... but any help will be so very much appreciated....
my gf has a honda rincon 250 that has major probs...when i get it to start by the manual pull start [starter and all is shot] i have to continuously give it gas or it will just shut off... while im doing it it tends to backfire quite a bit...
now i have cleaned the carb, cleaned the air filter, changed the plug... honestly i am out of ideas and need some help i was going to try and get it at least running by the end of the week [hoping!] i dont have either manual so if anyone can help on that would be greatly appreciated....
i am kinda thinking i need new vaccum line?? idk i can hear it sucking air though so i figured that was obvious but anything would help... pics would be amazing...
where i should have the pilot screw etc adjusted to would also be very helpful...
also as said above 5th gear doesn't engage its almost as though it skips over the gear or falls just between 4th and 5th any ideas here?
also it needs a lot of work... wat are some major thing i can do...
already
changed oil,
cleaned carb,
new plug,
cleaned air filter,
anything would be appreciated...
thank you in advance...
Old Mar 9, 2009 | 03:20 PM
pinetag's Avatar
I think you mean "Recon" 250. Anyway, the idle adjustment screw should be on the right side of the carb (if sitting on seat). The air/fuel screw is on the front (motor side) of the carb and is a little copper looking screw facing the ground. It should be 2 1/2 turns out so if your mixture is off then just screw it completely in and then back it out 2 1/2. If it has been sitting then you may need to drain the old fuel and put it in fresh. Also, check your fuel line for any gunky buildup. I know you said you cleaned the carb but after draining your fuel and checking the lines, I would clean it again and pay extra attention to the idle jet. They tend to clog up very easy as I have found out in my recon. A tip for preventing future problems, turn the fuel off and run the carb dry when storing.
You may need a valve adjustment too because tight (I believe) valves make for hard starting. Sorry I can't help with the 5th gear problem.
Old Mar 10, 2009 | 07:26 AM
thank you so much for all of that help...
i will take the carb off today and clean it once again and tamper with all the screws....
thank you soooo much
and what do you think about it sounding like its sucking air in....
vaccum? i assumed...
Old Mar 10, 2009 | 11:01 AM
pinetag's Avatar
Not sure about that. I would say to do a vacuum test by taking off the air filter and covering the hole with your hand and push starter button, but you said your starter isn't working. You can look at diagrams of the carb on cyclepartsnation.com and just look up trx250. See what lines are connected where and compare to your carb.
Old Mar 10, 2009 | 11:09 AM
dude i thank you to the highest your helpin me tremendously....
i will post back later to let you know about how the carb cleanin and adjustments went...
what about the jets and everything "inside" the carb when you take the float bowl etc apart...anything special anything to adjust?
thanks again...
Old Mar 10, 2009 | 11:11 AM
but everytime i pull the draw chord or w.e you call it it makes a noise like it sucks in air.... odd....
thanks
Old Mar 10, 2009 | 12:02 PM
pinetag's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: tommyramone55
thanks again...</end quote></div>
Nothing to adjust but i would make sure you unscrew them (phillips head) and pull them completely out so you can hold them up to the light and look through to make sure they're clean.
Old Mar 10, 2009 | 12:05 PM
ok... cool and screw them all the way back in [stupid but...]
i will post back later... i wont be working on it till prob 4 or so so i might just post back late or tomorrow....
Old Mar 10, 2009 | 06:17 PM
alright i printed the sum bitch and been tryin to figure out where each line tubing w.e you call it goes....
can you just show me a pic of your carb or send me a retarded kid picture?
thanks man....
Old Mar 11, 2009 | 10:30 AM
pinetag's Avatar
Don't really have any good pics but here is one with a few parts labeled...
bmxatv10
Oct 14, 2022 06:23 PM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
