1988 honda trx250r
Old Mar 10, 2009 | 07:54 AM
jcconstruction's Avatar
Default 1988 honda trx250r
hey guys, anyone ever had there 250r fall on its face like running out of gas. if i continue to hold the throttle it will completely die, if i let off and throttle back up it straightins out. thanks alot for any help.
Old Mar 10, 2009 | 04:22 PM
crankers75's Avatar
Check your float level in the carb it may be to low not giving you enough fuel in the bowl.
Old Mar 13, 2009 | 02:50 PM
thanks crankers
Old Mar 13, 2009 | 03:38 PM
dirtrider42087's Avatar
might sound stupid but is your gas tank vent hose twisted or anythin. i was riding a blaster before and it startd to die out while on throttle. then when id let off after a few seconds it was fine.
Old Mar 13, 2009 | 06:00 PM
crankers75's Avatar
Hey no problem you could also pull your fuel line off the carb and let it run to check and see that you have good flow. Theres a sreen up in the tank on your fuel valve they can get clogged!
Valder
Nov 28, 2020 07:38 AM
NewGuy2481
Oct 6, 2015 05:54 AM
rgjackson
Sep 17, 2015 11:21 AM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
