1984 200s carb question for swap
Old Mar 11, 2009 | 07:56 PM
rangerboy351's Avatar
Default 1984 200s carb question for swap
ok iv got a 1984 honda 200s it had a oxidised carb the idel air screw hole was huge.. ok now i had a carb from a 1982 honda 185s that was good i swapped the low speed jet beacuse the 200 had a smaller jet35 i think or similar instance then the 185 had like 38..the manual said the same. the main jet on both was 100 .i installed it run really ruff i cked the valve lash it was like .008 ex and .012 in. so i fixed that with re ajustment of .002 then adjusted the cdi pick up to .014 .so i did all this still run like it was loaded all the time really rich black exahust so i droped the main jet needle to the top notch to lean it out its decent no black exahust but just not perfect enough for me yet......well the only thing i did not do was switch the main needle jet seat on top the imultion tube... other then this what could be wrong? is the carb body diffrent? lmk thanks guys
Old Mar 13, 2009 | 11:36 PM
SMFREY's Avatar
I had the same issue with my 185s Carb
Still have not figured out why but I put another carb from later 200s jetted problem gone
I have tried several times going back to stock 185s carb runs rich black smoke
Good luck
Ray
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
