Running lean
Old Mar 12, 2009 | 07:36 AM
budedm's Avatar
Default Running lean
I've read some on here about the danger of overheating and melting a piston if running a bike lean. How can I tell if I am running lean? I have a stock 87 250X.
Old Mar 12, 2009 | 07:47 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Runs hot, deceleration backfire, spark plug is very light color.
Old Mar 12, 2009 | 02:18 PM
JeffinTD's Avatar
You might also notice surging at steady throttle...
Old Mar 12, 2009 | 02:49 PM
ironcowboy's Avatar
Question about the deceleration backfire, i get it sometimes on my 87 250x, is that something i should worry about? What should i check?
Old Mar 12, 2009 | 05:28 PM
Hawkman300's Avatar
ive been wondering the same thing about running lean. on my recon, it is naturally throatty, and whenever i decelerate, it makes a light popping sound repeatedly and unevenly sometimes, but not what i reckognize as a backfire. its not as loud as a backfire either.
Old Mar 12, 2009 | 06:26 PM
Red Rider
<div class="FTQUOTE"><begin quote>Originally posted by: Hawkman300
ive been wondering the same thing about running lean. on my recon, it is naturally throatty, and whenever i decelerate, it makes a light popping sound repeatedly and unevenly sometimes, but not what i reckognize as a backfire. its not as loud as a backfire either.</end quote></div>
The UNI air filter for the Recon, is much less restrictive than the stock one. If you are running one without a rejet....quiet likely you have added to the already lean condition it comes in from the factory.
Old Mar 12, 2009 | 11:41 PM
Tim Smith's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: reconranger
The UNI air filter for the Recon, is much less restrictive than the stock one. If you are running one without a rejet....quiet likely you have added to the already lean condition it comes in from the factory.</end quote></div>
Ditto. Most bikes and quads are jetted lean because of the EPA *****. A little popping (intermttent) is okay, but if your idle your quad for a while it is bad. Steady/ predictable popping on decel means you are pretty lean.
Frisky2050
Apr 9, 2020 11:19 AM
marioi911
Sport Quads
Jun 30, 2015 12:00 PM
Mphillips
Jun 26, 2015 03:52 PM
hoopduerr
Jun 10, 2015 03:00 PM
dano00
8
Dec 27, 2000 10:10 PM
