please help me wolverine wont run right
Old Mar 12, 2009 | 03:36 PM
zoom-zoom's Avatar
Default please help me wolverine wont run right
I just recently bought an 05 wolverine. It ran good. I rode it for about a week and everything worked fine. I took it out, ran it, got it pretty muddy, then I have no power. It would start to go then stop. I let it cool down then I could go a little then stop, finally after got it home it ran a little better, but still will not run right. You can go through most of 1st gear then into second the power cuts. If I go up a hill power cuts. The motor idles fine revs right up in neutral but in gear goes then stops. When you drive it it will go better when going slow but when you give it more gas it it will cut and backfire. I have checked the air filter and it was clean checked put new gas in with dry gas, checked wires and connections, checked oil, I put a new spark plug in I have cleaned the carb and it still does the same thing. Can anyone think of anything that might be causing it to run like this?? Please help.
Old Mar 12, 2009 | 06:03 PM
trickie79's Avatar
i know you said you cleaned the carb,but did the needle seat good and is their any unsmooth spots in it.pluse did you have ever jet out.and clean all ports with carb dip.
Old Mar 12, 2009 | 06:05 PM
trickie79's Avatar
unscrew sparkplug from boot and cut end rescrew on
Old Mar 13, 2009 | 08:08 PM
Jaime920's Avatar
Did you only clean the bowl on the carb out? did you unscrew the jets and make sure there was nothing obstructing them? I had what sounds like the same problem.
Old Mar 13, 2009 | 09:52 PM
95wolv's Avatar
Maybe check the parking brake switch, it will cut out the engine when in gear to prevent you from frying the rear brake if you leave the parking brake on. You should have 2 wires coming from the brake lever on the left side, follow them until you find a plug, unplug it and see if it runs better, if it does, most people cut the wires and tape the ends. My 95 Wolverine did not have that switch, and I DID fry my rear caliper and warped my rotor !! from 1996 on up, they put the switch in to prevent that from happening, but it tends to go bad, and your mud bath may have shorted something out. take a look and let us know.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
