02 yamaha blaster crankcase oil problem
Old Mar 13, 2009 | 04:44 PM
02yamahablaster's Avatar
Default 02 yamaha blaster crankcase oil problem
i just got my 02 blaster out from storage and i got everything on it running and ready for riding. i have my premix tank filled and my gas filled and i put 10w30 in my crankcase. i have noticed after about 30 minutes of riding there is no oil in the crankcase view finder. i know that it is still in the motor but i took it home and let it sit overnight. i looked the next afternoon and the was no oil in the viewfinder. i had a fmf fatty on the it but it wasnt a bolt on one, you had to use an exhaust spring for it to stay on. the fatty didnt fit on right and i looked around where the head and the fatty connect that there was an exhaust residue (like burnt oil or the same black exhaust residue in the tailpipe) and i didnt understand why it was there. i dont know if the crankcase oil was burning out fast because the fatty wasnt on right or what.
if anyone knows the answer or whats wrong with it please let me know...
Old Mar 13, 2009 | 09:57 PM
95wolv's Avatar
I'm a little confused, crankcase oil in a 2 stroke? do you mean perhaps transmission oil? I know the Banshee and Blaster took some oil for the gear case/clutch area, is that what you are referring to?have you tried adding a little more to see if it registers in the site glass?
Old Mar 14, 2009 | 08:33 AM
yes thats what i mean,
in the gear case/clutch area(i put it in right next to the kick start lever)
and ya i put some in the engine and rode it
after that i let it sit overnight and i didnt see any in there
but i just washed it up today and i noticed that there was oil in there just a little under half so i guess everything is fine so im going to put the fmf fatty back on it
thanks alot tho for everything if theres any more problems ill post it
Sjrpp
May 2, 2023 03:59 PM
Frisky2050
Apr 9, 2020 11:19 AM
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jul 5, 2015 09:04 PM
