'91 Honda 250X Mods??
I have a all stock Honda 250x that i've been beating around in for the past 2 years. Now i'm at the point where I need MORE SPEED!! Are there any mods that would be worth buying or should I think about geting a new one?
Thanks for yur help!
There are all kinds of Mods you can do to your bike. The best way to get started is to bolt on a K&N filter, a new pipe, and re-jet the carb. That will give you a significant difference. If thats not enough for you, you need to go internal. You can go to a higher compression piston or a bigger bore. You can put in a cam. You can also do a little porting and polishing to the head.
If your really in the need for speed, you can put your bike in the paper and go down to your local Honda dealer and buy a new 400ex. Good Luck.
ElementzzofStyle
Aug 29, 2015 10:45 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Jul 22, 2015 05:00 AM
