Rim Sizes
Old Mar 16, 2009 | 11:25 AM
chrisclevenger's Avatar
Default Rim Sizes
What are the original rim sizes of a 2004 foreman es? Front and rear.
Old Mar 16, 2009 | 01:02 PM
680's Avatar
680
Default Rim Sizes
12 inch front and rear. tire sizes are 25x10x12 rear and 25x8x12 front. i beleive they used dunlop that year. the kt128 and kt405c were both used on the rear. not sure what tread they used on the front
Old Mar 16, 2009 | 02:05 PM
Default Rim Sizes
DO you know what the width is? I just bought new tires 26-10-12 on front and 26-12-12 on back. Im lookin for somw cheap black rims to put on them, but I cant find the width of them.
Old Mar 16, 2009 | 02:20 PM
680's Avatar
680
Default Rim Sizes
factory are 12x7 front and rear
Old Mar 16, 2009 | 02:23 PM
680's Avatar
680
Default Rim Sizes
a good low price rim is the itp delta steel wheels. that is what many shops use on their mud lite tire/wheel kits. 26x10x12 front and 26x12x12 rear
Old Mar 16, 2009 | 02:25 PM
Default Rim Sizes
Thanks
Old Mar 16, 2009 | 02:42 PM
680's Avatar
680
Default Rim Sizes
the delta steel wheels are all 12x 7 like your factorys. if you order, have them tell you what offset you need and the lug nut requirements- if your lugs are tapered like a car or truck or if they are flat lugs. they should be able to teel you all that if you teel them what atv you have. atv's with an axle and ones with independent rear suspension require different offsets. irs is wider across than axles. if you put a deep offset on a irs rearend, the tires will stick out too far and it will look funny and if you try to use shallow offset on an axle rearend, they may hit the brake drum from not enough clearance. go to dennis kirk.com and see if they have that info on their site
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
