Wheel Spacers and Adapters
Old Mar 20, 2009 | 03:30 PM
Twin LT80's's Avatar
Default Wheel Spacers and Adapters
Looking for a little help from someone who maybe has machined their own wheel spacers and/or adapters, especially for the LT80.
The question basically is on bolt pattern dimensions. For instance, I have a set of wheels for my daughter's LT80 (3/120mm) but it has a 4-bolt pattern. The wheels are ITP Aluminum and are 10x6 with 19-6/10 Holeshots.
I like the wheels and want to machine an adapter since, as an added bonus, it will widen the front end.
The guy told me that they came off a Honda trx90 which I believe should be either 4/85 or 4/90. However, I mic up closer to 4/88. Don't know if this was on a Kasea or some other knock off and that's why the seemingly odd bolt pattern.
I have laid out a 3/120 to 4/88 adapter but don't want to begin machining until I can confirm the spacing. If I don't get an answer I will mill up some bar stock and see which dimension allows bolts to line up, but I thought if someone did this they could help me out.
Once I do this I'd like to swap in a pair of Kasea front shocks. Are the Kasea 90's a direct bolt-in?
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
