HELP Rear end 02 Honda Recon
HELP!!! I have a 02 Honda 250 Recon and this bike I just bought. I am redoing everything on it. The boy that had it had no factory sticker left on it, it was covered in 100 other stickers though. The plasic it tan and I bought the silver replacement stickers. I sanded the racks and sprayed them with Dupli-Color Spray in Bed Coating (it's a rip off of Rhino Liner but seems to be tough). I am totally rebuilding the rear-end and can't get the bearing out of the swingarm tube or the cover for the brake drum. Any ideas I know about the circle clip but can't get them to budge either. The engine is a fresh build with a new sleeve, piston, wrist pin, and bottom end has new bearings. I know it was a beast to get the l axle nuts loose that hole the bearing in on the brake side. I had to pull the axle and take it to a local four-wheeler shop and have them loosen the nuts. Any help on them bearings would be a great help thank you!
What a forum 33 views not one reply but i got it fixed and it is up and running great! I still gotta put the new back brake lines on (hand and foot), the fender supports, then I'm going to put the plastic on and apply the factory sticker kit, then put the racks back on then I'll add some pics to my profile
