yamaha triz 250
Old Mar 21, 2009 | 12:01 PM
trikerider24's Avatar
Default yamaha triz 250
i have a 85 tri-z. runs great low end to mid but cuts out in high rpm range. its not fuel issue. any suggestions thanks.
Old Mar 21, 2009 | 03:25 PM
JLsparky7's Avatar
Jetting, need a bigger main.
Old Mar 21, 2009 | 05:02 PM
habitatjoiskater's Avatar
Yes it is a fuel issue, like Sparky said jetting
Old Mar 21, 2009 | 05:08 PM
91Warrior357's Avatar
most likely it needs a bigger main, but the reeds might be causing this also.
Old Mar 21, 2009 | 08:57 PM
Raptor450's Avatar
I'm glad to see there are some more 3 wheeler riders here. I have 2 Tri-Z's I'm restoring now.
You say this is not a fuel issue, how did you determine that? The other possibility is your spark gets weak at higher RPM from a bad stator, regulator, or ignition coil, need to test those with a meter. If you need a coil, the Warrior and Blaster coils are the same. The Blaster and Banshee regulators are the same.
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
