piston rings
Old Mar 21, 2009 | 04:14 PM
ghettodawg's Avatar
Default piston rings
i was just wondering if i were to get new piston rings what all else would i need to get when i do a pistyon ring change? do i need a whole new piston? a rebuild kit? top or bottom? and how complicated is it to change a piston ring?
Old Mar 21, 2009 | 04:58 PM
JeffinTD's Avatar
A person would want to take the cylinder and piston to a machine shop and let them measure it. If it isn't worn beyond limits, a hone can be run through the cylinder, and the piston and cylinder can be reused with new rings.
If the cylinder is beyond limits for taper, out of round, or diameter, it will need to be rebored to fit a larger piston. In either case you would need the appropriate gasket set.
If you don't have a service manual, get one. If you haven't done this kind of project before, it would be a good idea to invite an experienced buddy over.
Old Mar 21, 2009 | 05:00 PM
Magnus112's Avatar
if it is a 2 or 4 stroke you will need all gaskets to repalce the old ones. you will also need to have the cylinder bored for a bigger piston
or just deglazed or honed you can do this or take it to a motor shop. as far as tools basic tools are needed along with a good to to torque
wrench a repair manual always helps for all the specs.most pistons just is that piston- rings and wrist pin...gaskets are extra
what ever help that is
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
