91 Trail Boss Chain and Sprocket removal
Old Apr 2, 2009 | 04:19 PM
Bfcnb's Avatar
Default 91 Trail Boss Chain and Sprocket removal
Hello all!
I have a 91 350L Trail Boss 4X4. I'm getting ready to order up a new chain and sprocket set for the rear chain on my ATV. What is the best way to change the front sprocket for the rear chain on this machine?
The guy that I got the wheeler from decided to pull a Farmall "A" tractor about a mile with it. After that, you could hardly drive it with out the chain slapping or jumping. Luckily he did it in 2 wheel, the front chains and sprockets look good!
Thanks for any help!!!
Old Apr 2, 2009 | 04:35 PM
drlang's Avatar
You will need to loosen the front carrier, then the center carrier. Remove the outside gear from the trans, then the bearing plate. Now the rear stuff should be exposed.
Old Apr 2, 2009 | 05:16 PM
Bfcnb's Avatar
Will do!! Sounds Good!
Thanks for the quick response!
95wolv
Jul 17, 2015 08:13 PM
Desimation2k8
Jul 17, 2015 12:37 AM
1000gade
Jul 16, 2015 10:48 AM
joeyupton
Jul 14, 2015 11:51 AM
Unzzy66
Jul 11, 2015 10:01 PM
