Where the heck is my spark plug(s)?
Old Apr 3, 2009 | 09:04 AM
Tpr430's Avatar
Default Where the heck is my spark plug(s)?
Can somebody tell me specifically where my spark plug(s) are and how to get to them. I have an 05 sportsman 600 and I wanted to change the spark plugs. Thanks in advance!!
Old Apr 3, 2009 | 09:25 AM
Pull your right and left side panels off,right side plug easily to get to,but left plug up under clutch air tube. SMALL hands an asset,but you can get it out. I use a long pair of needle nose pliers to first twist and turn plug wire boot and then pull boot up.If you just pull up on boot with pliers ,dirt and water that has settled can cause you to damage boot. I have a small 5/8" plug socket with a 1/2" socket head that I use. Or You can use a regular plug tool with a small extension and ratchet. IF never have change before,replace champion plugs with NGK BKR7ES.
Old Apr 3, 2009 | 09:34 AM
Tpr430's Avatar
Thank you tech! I'm going to go out and look right now.
Old Apr 3, 2009 | 10:14 AM
Tpr430's Avatar
OK, I found em. How much do I twist the boot, 1/4 turn? I dont want to damage it, I have a tendancy to do that.
Old Apr 3, 2009 | 12:22 PM
xplorerman's Avatar
1 inch or so
Old Apr 5, 2009 | 08:54 AM
Tpr430's Avatar
...and what do good spark plugs do for a machine?
Old Apr 5, 2009 | 11:12 AM
Wink
Makes em run better and less fouling!
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
