200sx Owners please reply...
Old Feb 13, 2001 | 08:33 PM
mudslinger85's Avatar
I just had 2 go to the honda dealership 2 get a new chain and sprockets for my 200sx, while there I asked the guy who was talking 2 me, about my front brakes and told him how the master cylinder was messed up and he went outside and got the whole assembly off of a old street bike and told me it would work I just had to bleed the brakes. I installed it but didnt have time to bleed them and they wouldnt work, so I was going 2 wait until the next day to bleed them. The next day when I checked on it I had front brakes, they work just not as good as I would like. Is it possible they bled themselves? How do I bleed them?
Old Feb 14, 2001 | 12:07 AM
bermbanger's Avatar
well dude if you wanted more replies you would have said brake trouble not just 200sx cuz all hydraulic drums work the same.yes my brakes bleed themselves.it happens when you don't get the cap on tight enough but not too loose
Old Feb 14, 2001 | 04:23 AM
JRM's Avatar
JRM
yes, the air will travel to the top...but to get all air out bleed them as follows: Fill resivor, apply brake and dont let it go while you open the bleed vavle on the brake drum. The handel will go to the bar but dont let it go until you close the vavle on the drum. Once closed let the handel go and pump the up again and fill with more brake fluid every 2-3 times you open the bottom valve. Just repeat as many times as needed to get the air out. (usally 3-8 times)
Old Feb 14, 2001 | 07:37 PM
ATV_MAN's Avatar
LOL, GOOD LUCK ON THE BRAKES!!
I NEED A MASTER CYLINDER(BRAKE RESIVOIR) RE-BUILD I THINK, MY BRAKES HAVE NEVER WORKED GREAT.
THE 200SX BRAKES ARE JUNK.
Old Feb 14, 2001 | 08:32 PM
JRM's Avatar
JRM
my rear have never given me greef, always been sweet...but the front only barly lock up as nothing happens until about a 1/2 inch from the bar
Old Feb 14, 2001 | 10:13 PM
bermbanger's Avatar
hey atv man adjust the front brake pads so that they are slightly touching the drum and bleed em good and they'll be fine
Old Feb 14, 2001 | 10:23 PM
ATV_MAN's Avatar
No...to make my brakes have any friction I have to pump the brake lever at least 10 times before the brakes come on. When I let the lever go there is no pressure when I put the lever back in so I have to re-pump it 10 times.
I think the Piston inside the resivoir is seized or jamed somehow.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
