08 800xp
Old Apr 9, 2009 | 07:46 PM
adrian7070's Avatar
Default 08 800xp
can someone tell me if i will need spacers to fit bigger tires on this quad?
Old Apr 9, 2009 | 09:16 PM
switzomatic's Avatar
Default Tires
If you are only putting taller tires on there will not be any issues(unless you go up more than one size then you will be looking at a lift kit). If going wider then take some measurements to determine if you need spacers.
Old Apr 10, 2009 | 06:24 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
anything larger then 27" tall will need a lift. the only issues is the front tires wider then stock like a 9" is extremly close or might rub. w/ after market rims that already have the offset its not an isue or you could put 1" spacers on and be ok as i well i beleave. imo
rv
Polaris Side by Sides
May 13, 2015 05:25 PM
MortisFK
Apr 11, 2012 05:23 PM
