2002 Polaris Sportsman 700 Clutch Kit?
A newbie here. Just bought a 2002 sportsman 700 and got it delivered last night. (Easter) I want to put in a clutch kit. I trail ride,light mudding,light-mid pulling,slow rock crawling. Bone stock machine, stock tires, 750 foot elevation. Whos clutch kit do you recommend? Reading about Dalton,Speedwerx,EPI,Straight Line Performance,Bikeman... Any other suggestions for this model? Thanks
I like the HC kit the best adjustable weights.. You might want to get a 2006 or newer Primary clutch and Team roller secondaryon the POPO 700 & 800's. Gearing a lot lower....
Also does anyone have any experience with the dyno jet kits and K&N air filters? I know the sleds will run alot better with proper clutching and jetting. I would think the same rule applies on a quad. Thanks
well he^^^^ is the king on the 700 mods for sure. but for having a heelclicker on a sp. 450 and an 800 they arent worth the money for the gains for get. im not going to get into a big debate about this as like i mentioned, their is alot of views out there. if perforcemance is what you want, then sp70003 is your man for sure.
I had an EPI big tire kit in my 05 800 and it rocked. Also ran K&N, Aaen pipe, 6" Gorilla lift, and Outlaw 29.5" tires and it would pull the front end right up. I would definitely clutch and add a K&N but caution re-jetting if your machine runs good where you are. Jetting will give you a boost(if dialed in) but then you will have to deal with your ride being more sensitive to temp changes and such. I had an 02 700 and ran K&N, 2" lift, and bigger tires with no issues.
Anyone have any experience with the Team Industries stage 2 kit? It comes with the roller secondary. I know the roller clutches are great. Just never tried one on the atv's yet. I have rode the new Sportsmans that have them and i think they are real smooth. I am kinda leaning this way. Hopefully some feedback will follow.
Dakosk
Jun 6, 2015 05:37 PM
May 27, 2015 11:15 AM
