New owner questions on 2007 SP800EFI
Old Apr 13, 2009 | 09:30 PM
Seuss's Avatar
Default New owner questions on 2007 SP800EFI
When I was adding the switch for the work lights on my 2007 800 EFI and i cut the cable tie to get to the plug connector i discovered a 9V battery connector. My first thought was a battery back up for the Digital speedo info but when i disconnected the speedo to drill the plastic pod the info was retained except the clock.
Does anyone know if that is for the clock backup?
The other question i have is about the fuel line that runs up into the pod. It was not connected to anything but next to it was another hose with a t fitting on it with two filters. I connected it to one of the nipples and the engine runs just as good as it did before hooked it up.
Anyone know what that is for? I was thinking tank vent since it is EFI.
Seuss
Old Apr 13, 2009 | 09:41 PM
Rowe's Avatar
If I remember correctly it was for the techs building them at the factory to check the speedo or computer since they do it b4 it has the battery installed.
Old Apr 13, 2009 | 10:00 PM
Seuss's Avatar
Cool thanks
Old Apr 13, 2009 | 10:10 PM
Seuss
The 9 volt battery connection is for use when reflashing,checking out,turning off codes on machine,etc when using dealer digital wrench software on their computers. I keep a fresh 9 volt battery handy at all times!
Old Apr 13, 2009 | 10:18 PM
Seuss's Avatar
Thanks for the info. Any idea on the fuel lines in the pod?
Old Apr 13, 2009 | 10:24 PM
Just vent filters, also to help keep moisture out of lines.
Old Apr 14, 2009 | 05:39 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure these vent lines are free from being pinched or blocked to prevent any issues as well.
Cole Hadden
Jun 15, 2025 09:05 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
austinwhitton
Aug 11, 2015 06:21 PM
Sjrpp
Jul 5, 2015 09:04 PM
