04 sp500 belt question
Old Apr 16, 2009 | 05:45 PM
wrenchnnutz2's Avatar
Talking 04 sp500 belt question
i seen on this forum a few years ago about being able to put a belt from a 700 on to a 500 and it would change your performance (more bottom end or more top end, i'm not shure) has anyone heard of this or done this with any good results???? i got a 04 so 500 and it's time for a new belt and was just wondering.
Old Apr 16, 2009 | 07:43 PM
Koerbs's Avatar
It won't give you any preformance boost, and if that was posted on here as advice, I'd like to see that post.
A 700 belt probably won't fit on a 500 because the motor and trans are mounted different than a 500 and if it did fit, it would be the same part number and therefore wouldn't change a thing.
Old Apr 17, 2009 | 06:56 AM
switzomatic's Avatar
Default Belt
Sounds like smoke and mirrors to me. Make sure you only use the Polaris belts. They cost more but are worth it! Bought a "high performance" aftermarket belt for my 02 700sp and it lasted all of 100 miles before dynamiting. Replaced with a stock one and never had any issues. If your belt isn't too bad when you replace it hang on to it as a spare if needed in a pinch.
Old Apr 17, 2009 | 07:09 AM
Kerbbirds's Avatar
The 800 belt will fit a 6 or 700 but I dont think those belts will fit a 500, next time I have my 500 apart I will check it out.
Old Apr 17, 2009 | 07:12 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
actually i posted a long time ago about how i put a 700 belt on my 02' 500(which you can do and it fits fine) but didnt mentioned and is false about giving any more perforcemance as a belt change wouldnt give anything. bvasicly back then the difffernce was a 700 was a top cog groove belt wear the stock wasnt and a 700 belt ran cooler. imo
Old Apr 17, 2009 | 08:14 AM
TLC's Avatar
TLC
Use the Belt for your ATV. The only thing I remember abot the 500s is there are smooth tops belts and coged top belts for them.
The cog top belts are suppose to help circulate air in the belt housing better.
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
Logan Collins
Sep 5, 2015 08:03 PM
