500 sportsman. Whats wrong with it?
Old Apr 16, 2009 | 11:31 PM
honda doc's Avatar
Default 500 sportsman. Whats wrong with it?
I have a 99 sportsman 500 here that needed a cam and a carb rebuild which I did. 2 weeks later it has some of the same symptoms it had before. At WOT it goes about 20 mph and surges alittle. Take the airbox off and it has all kinds of power. Even putting on the 2 inch long rubber hose that connects the carb to the air box makes it act up. I checked the valve clearances, timing, loosened the muffler, raised and lowered the clip on the needle. Nothing helped. There is nothing blocking the snorkle or airbox tube. A F is a KN with no prefilter. What am I missing?
Old Apr 16, 2009 | 11:38 PM
Magnum-X's Avatar
Have you rejeted the carb. A K&N is a very free breathing filter that can require rejetting. If you have it it may also be that you haven't got the Air/fuel mix dialed in.
Old Apr 16, 2009 | 11:43 PM
honda doc's Avatar
No i didnt rejet. And I am alittle skeptical about the kn, The thing is it ran great for two weeks
Old Apr 17, 2009 | 07:16 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check your spark plug to see if its running rich. if running w/out the filter runs fine then sounds like it richens it right up w/ the filter back on.
Old Apr 17, 2009 | 07:24 AM
Kerbbirds's Avatar
Will it rev up in nuetral? Is it just doing this while riding? Might be the Buttons in the secondary clutch instead of the motor.
Old Apr 17, 2009 | 10:22 AM
honda doc's Avatar
Thanks for the input guys
It does rev up in neutral but its choppy and inconsistant. I will check the plug again and reajust the mixture screw. I haven't done anything with the electronics either. thanks for the suggestions
Old Apr 23, 2009 | 08:03 PM
Magnum-X's Avatar
How did you make out doc?
Old May 4, 2009 | 10:03 PM
honda doc's Avatar
still puzzling it out. i found a crack in the tube between the air box and carb. a new one made no difference. the slider in the carb just doesn't seem to want to move. I took it all apart and cleaned it and now it runs good again. No idea why. I'm just waiting to see how long it lasts. what is the valve lash supposed to be? thanks guys
Old May 7, 2009 | 10:24 PM
goodblasson's Avatar
keep me updated...
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
Bigtwin700
Sep 10, 2015 10:46 PM
