radiator trouble
Old Apr 18, 2009 | 11:42 AM
200es's Avatar
Default radiator trouble
hey last night i was rideing and must have picked up a rock in my raditor and have a leak in the side by the cooling fins. has anyone else repaired one before? i think the hole is to big for for the stuff you pour into the rad. any sugestions are welcome
Old Apr 18, 2009 | 01:53 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
You can take it out and a Auto repair shop for Rads should be able to sodder it....................Did you price a new one?
I myself would replace it do to the fact when your 2-3 hours back in the bush,I don't want to worry about that all the time.......
If used close to home or even roads....It's your call Might be able to limp home if you ever need to
....Caper.......
Old Apr 19, 2009 | 06:10 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
depends on where the hole is like caper said about having it fixed or maybe even recorred if they do atvs like autos. if not start looking around for a used one as they wont be cheap.
Old Apr 19, 2009 | 10:42 AM
TLC's Avatar
TLC
there about $125-$150 on E bay for a good used one.
Old Apr 19, 2009 | 10:28 PM
200es's Avatar
Default radiator
i tryed a self fix that so far is working good. i sanded down all around the hole and used plyers to squeeze the hole shut and applyed lots of jb weld to it. so far so good i'm only going close by my house to test it but i think it will hold
Old Apr 20, 2009 | 05:16 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its the back yard special that works the best sometimes and saves the most $$ keep an eye on it.
Old Apr 20, 2009 | 06:27 AM
Rowe's Avatar
Good luck! I have used J B Weld on the case of my 250x and it held up great. I would keep an eye on it for a little bit, and also keep an eye on your temp. I would say if it was going to leak it would have done it right off the bat. With the fins the J B has a lot to grip on and will probably out last the rad.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
