Polaris 500 stuck in low gear
Hello.
All of a sudden, I can't seem to get the thing out of gear! I was working with it on Saturday.....working fine. When I went to put it up at the end of the day....couldn't get out of LOW. No nuetral, nothing. Had to literally push backwards to back up.
2000 Polaris Sportsman 500
AT, no clutch.
Advice?
kempisjobs@hotmail.com
Thanks
AT, no clutch.
Advice?
Thanks
I am trying to post on the site and am unable to do so. If anyone knows of a source for a pressure regulator for a Polaris 2006 Sportsman 500 EFI HO, other than purchasing the entire fuel tank from Polaris please let me know.
Thanks
Jean
Thanks
Jean
Hello.
AT, no clutch.
Advice?
Thanks
AT, no clutch.
Advice?
Thanks
Yes. I shut it off, rocked it back and forth, everything.
Some quick advice I got at work yesterday after talking to another Polaris owner told me to try and apply the rear foot brake when trying to shift. Nothing. It's been suggested that if I take it out of AWD, that may work....nothing. I've tried pulling it out of gear when it's on (idling), when it's off with the key both on and off.
The only thing that I can think of is that when I last put it into LOW, I had just backed down a grade, applied the brake, and put it into LOW. When I tried to take off, it bogged, almost like it was running out of gas or something, but then it lurched forward and I never gave it another thought. I don't know if this has anything to do with anything or not, but it just seemed significant.
Also, last night when I tried to apply the foot brake, it seems VERY stiff. Again.....don't know if this is any indication or not......plus I rarely use the foot brake, so I'm not that familiar with how it normally feels.
I have a repair manual that I bought for the bike, but haven't had time to dig in. Will that thing help me at all?
Thanks alot for the help.
Kempis
Kempis
the foot brake had nothing to do w/ it as on some models around 04' area you needed to apply brake to get it out of park. sounds like maybe a bent shifting fork if when its off you cant it out of gear. the only other thing is to unhook the shifting linkage to see if you can manualy take it out of low w/ the levrs on the trans. to see if its the linkage is the issue. just an idea.
if you have the tools and a book your doing alright compared to flying blind. you need to find out if its the linkage or if its inside thats the issue would be my first move if it were me. good luck.
Hello.
AT, no clutch.
Advice?
Thanks
AT, no clutch.
Advice?
Thanks
Mphillips
Jul 29, 2015 08:53 PM
hoopduerr
Jun 2, 2015 09:01 AM
