scrambler no spark
Old Apr 24, 2009 | 06:57 AM
cummins-dodge's Avatar
Default scrambler no spark
i have a 97 scrambler 500 it turns over but there is no spark as soon as i hit the starter button it put spark out but it stops and when i let off of the button it does the same the pull rope has been broke for a while so i took the cover off and the pull rope was shreaded in there i cleaned it and every thing seens to be ok
Old Apr 24, 2009 | 02:23 PM
can any one help me with this problem no spark
Old Apr 24, 2009 | 03:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like its grounding itself off if your having fire until you let off. is the switch good? would it fire and run w/ the pull cord?
Old Apr 24, 2009 | 03:47 PM
there is no pull rope on it now
Old Apr 25, 2009 | 10:15 AM
it will start if you push the start button on and off fast but if you just hold the start button it wount start it just turns over
Old Apr 25, 2009 | 12:54 PM
eggenz7's Avatar
does your switch the type that has the starter switch and the kill switches combined into one? have to push up on the switch for the starter and kill is side to side?
if so i would try cleaning that switch assembly. what i did on mine was find a bike that had two seperate buttons for the two functions then wired into my electrical..works fine now
Old Jun 22, 2009 | 06:53 PM
rescueranger778's Avatar
have you figered out the problem i am having the same problem with the same model scrambler and cant figer it out thanks
Old Aug 29, 2009 | 07:46 PM
i figered out the problem the pulse controler on the left side of the flywheel has been pushed back from the flywheel push it back closer to the wheel it fixed mine
mitchxc700
Aug 19, 2015 02:41 AM
scram5050
Aug 19, 2015 02:19 AM
mitchxc700
Aug 10, 2015 09:26 PM
1000gade
Aug 9, 2015 03:34 PM
maxjung
Jul 13, 2015 05:11 PM
