Roller secondary vs. Stock
Old Apr 30, 2009 | 08:55 PM
trybaj17's Avatar
Default Roller secondary vs. Stock
I am thinking about ordering the roller secondary that RCR has. Does anyone have this, and what do you think of it.
Old Apr 30, 2009 | 09:52 PM
plumbob's Avatar
First we need to know which secondary clutch you have right now and which type of roller that RCR is selling.
Old Apr 30, 2009 | 10:16 PM
trybaj17's Avatar
Its the stock secondary that came on the quad, no EBS. i put a Polaris purple secondary spring that Rick sent me last summer.
Ritter Cycle Racing - FAST, NOT FICTION. --> 4th from the top
HPD Roller Conversion: $150
Get the smooth action of a roller clutch with this conversion! Includes new helix
Old Apr 30, 2009 | 10:21 PM
trybaj17's Avatar
its a HPD secondary conversion that Rick is selling
Old May 1, 2009 | 06:11 AM
ftwflh's Avatar
GO with a TEAM roller secondary set up by HPD.Rick sells them.This is the one most noticable mod I have done WELL WORTH THE $$$$$$
Old May 1, 2009 | 06:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
big improvement w/ a team roller for sure.
Old May 1, 2009 | 12:37 PM
trybaj17's Avatar
Ok so then Rick sells the TEAM roller secondary right, or do i have to go through HPD? and will one of them work with a 2002 325 magnum?
Old May 1, 2009 | 01:19 PM
midnightxplorer's Avatar
Does it work with ebs? What about low end and top speed?
Old May 1, 2009 | 03:19 PM
trybaj17's Avatar
yeah i was also wondering what the roller secondary will do for the top end and low end of the rpm range, and also speed wise?
Old May 1, 2009 | 06:33 PM
ftwflh's Avatar
IF set up right it wont effect your top speed.If you want good top end go with a EPI pink primary spring then have Rick get your TEAM from HPD with a helix and spring that is needed.
THe reason for getting the HPD modded TEAM is they add a mod to help set belt deflection.
And if you have EBS TEAM makes a secondary for that too.
