Roller secondary vs. Stock
Old May 1, 2009 | 07:24 PM
trybaj17's Avatar
last summer when i ordered my stage 1 kit from RCR, Rick hooked me up with a Dalton black and white primary and a polaris purple secondary spring. Will the black and white the same as the EPI pink primary?? right now i have slight belt rub when i let off the throttle. will this go away with the roller conversion?
Old May 1, 2009 | 09:05 PM
ftwflh's Avatar
I forgot you had Ricks stage1 kit.Let him set the spring in the TEAM to match the rest of the kit.
The EPI pink is a good spring for a stock 325/330
Old May 1, 2009 | 09:39 PM
trybaj17's Avatar
is the dalton back to stiff, for a stock 325/330?
Old May 2, 2009 | 06:53 AM
ftwflh's Avatar
A TEAM roller uses dif type of spring and helex
Old May 2, 2009 | 03:49 PM
  #15
trybaj17's Avatar
i have the black and white for my primary? and right now i have a Polaris purple, so i know that now i need a different spring. how do they differ?
Old May 2, 2009 | 10:57 PM
  #16
ftwflh's Avatar
TEAM springs work dif from stock
Pehter
Oct 3, 2024 11:00 PM
dannytas
Sep 26, 2017 06:31 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
