Roller secondary vs. Stock
Its the stock secondary that came on the quad, no EBS. i put a Polaris purple secondary spring that Rick sent me last summer.
Ritter Cycle Racing - FAST, NOT FICTION. --> 4th from the top
HPD Roller Conversion: $150
Get the smooth action of a roller clutch with this conversion! Includes new helix
GO with a TEAM roller secondary set up by HPD.Rick sells them.This is the one most noticable mod I have done WELL WORTH THE $$$$$$
Ok so then Rick sells the TEAM roller secondary right, or do i have to go through HPD? and will one of them work with a 2002 325 magnum?
IF set up right it wont effect your top speed.If you want good top end go with a EPI pink primary spring then have Rick get your TEAM from HPD with a helix and spring that is needed.
THe reason for getting the HPD modded TEAM is they add a mod to help set belt deflection.
And if you have EBS TEAM makes a secondary for that too.
