660 GRIZZLY-top speed 40mph
Brother in law tried a mud hole that was a little to much for his bike. Took a while to get it running and now top speed is only 40mph. Did pull the cover off over the clutch and cleaned it the best he could. What is the best way to clean these. Any help would be greatly appreciated. thanks
check the transmission and see if there is still some water in there because on my 2001 grizz 600 it does the same thing if I take it in too deep water, or if you don't feel like doing all that just run it hard until the water goes away.
FWIW I take my Kodiak 450 swimming many times in water over the fenders and have never had water enter the transmission thanks to my simple $20 snorkel.
The rest is just ABS pipe/elbows from the hardware store and I painted mine black with vinyl paint to make it nicer looking than just the black pipe with writing on it.
If after cleaning the clutch, it still tops out at 40 mph, check the inside of your primary sheave. Mud can get into it and prevent your clutch weights from rolling all the way and keep you at low speeds.
