starter voltage and clutch align
Old May 4, 2009 | 08:06 AM
marmon's Avatar
Default starter voltage and clutch align
When cranking how much voltage should be across the starter? im getting 11-11.2? too low?
Also what is a good way to shim the secondary out to the proper alignment with the primary?
My secondary has 0 float and it always seems the belt sticks to one side of the primary and it creeps. Also how tight should the belt be run on these?
Thanks
Old May 4, 2009 | 08:15 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should be pushing 12 volts or close when cranking over. buit if it starts at that lower voltage and is charging fine when running, i wouldnt worry about it as my 800 sometimes goes down to 11.8 while its cranking over. depending on wheather its an ebs clutch is to how much tention on the belt. make sure the engine mounts are good on the engine so its not moving causing misalignment of the clutches.
Old May 4, 2009 | 10:58 AM
marmon's Avatar
Default battery voltage
Well it starts fine sometimes, but alot of the time the bendix won't engage.
I've had a new one put in, and it moves freely. I am back at the battery now as a source to why it takes 2-3 tries to get it to engage. I bought a canadian tire battery last year, and I'm hoping its the culprit. I have the EBS clutches, and have a heck of a time shifting as its always trying to drive itself. The primary is almost new, as well as the belt?? I also pryed up on the motor a bit and it seems tight. I tried checking alignment, but its almost impossible as theres nothing to referance to. Any ideas?
Old May 4, 2009 | 12:05 PM
all_stock's Avatar
I have a 99 Sportsman 500 EBS and the belt deflection should be 1 1/8" to 1 1/4".
Old May 4, 2009 | 12:56 PM
marmon's Avatar
Default belt height
roughly how high does your belt ride in the secondary?
Mine is 1/16-1/8 out. My deflection is no where near that!! especially if the EBS pulley grooves arent in line with the grooves in the belt. The other question is i have huge clearance between the belt and the primary almost 1/8" Is this normal? I don't believe i have any shims on the spider, maybe one.
Old May 4, 2009 | 02:43 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that is the correct height of the belt over the secondary. therre is a clutch aligment tool to use to make sure thie rset correctly. if the belt is rubbing hard on one side of the primary it might be out of alignment. its most likely the correct shim in theclutch unless its been apart. if the belt isnt dragging hard onthe clutch face and still is trying to creep ahead then maybe(common issue)the ebs bushing or fiber washer is worn out. there isnt too much belt deflection on an ebs clutch as if there was, then the ebs wouldnt work correctly. imo
Old May 4, 2009 | 03:20 PM
all_stock's Avatar
If your belt is not touching the primary sheeves what is turning your belt? Think about it. You just said you have an 1/8 gap at the primary the drive is most likely coming from the center of your primary . By adding shims to your secondary you will increase deflection and this should eliminate the tension between the primary and secondary at idle. This is a problem I have encountered after local dealer installed new clutches and belt. They told me you don't need to setup deflection on the new ebs clutch. So I bought 3 shims at 2$ each from him and my problem is gone.
Old May 4, 2009 | 03:30 PM
marmon's Avatar
Default gap
1/8" gap when the belt is pushed to one side, where it goes naturally
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
ghost civic
Jul 15, 2015 10:48 PM
