AWD light
Old May 6, 2009 | 10:56 PM
DARETORIDE's Avatar
Default AWD light
On my 01 sportsman 500 HO the light for AWD will turn on and off randomly when awd should be on.... the light is mostly on....but when the light turns off while driving does this mean that the AWD is not on?? Switch broken??
Old May 7, 2009 | 03:08 AM
chuck_raduenz's Avatar
since the switch is "ON" and then the light is flickering. id first check the switch. since the light can only be on with the switch. then if the switch is fine check the bulb. but it soulds like theres either water, or some kinda corshion on the connection. clean it, and add diaelectric grease to it. see if that helps it.
if your spinning you should beable to tell if its shutting off. if your driving at road speed "im not shure on this answer" but it may be shutting off at a certain speed. i know the newer sportsman do. but dont know if the older one do also.
Old May 7, 2009 | 05:34 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i think you'll find when the light is out you dont have awd. i would look for a corroeded wires/switch as well as stated above.
Old May 7, 2009 | 10:42 PM
DARETORIDE's Avatar
The light is not flickering but it will be one most the time and then turn off for a little bit like 10 sec to 1 min and then is on until i shut if off... Could fluid be low in hubs or anything like that...and am I checking the switch on handle bars or some place else...I dont think the handle bar switch would be corroded...
Old May 8, 2009 | 01:14 AM
i will post a simple wire diagram of the awd circuit. i had it almost dont but my computer foze, and now i have to start all over.
Old May 8, 2009 | 03:36 AM
hope this helps. i didnt feel like drawing out the whole wire diagram. so heres what i think is importaint to help you understand the wireing. if needed get a 12v test lik and check some things. it may evon be a ground.
Old May 8, 2009 | 04:47 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there should be power still going to the hubs even w/ low fluid, so my guess is that wouldnt be causing it. the switch could have corroded contacs. i would still check it just to rule it out. imo
Old May 12, 2009 | 04:40 PM
DARETORIDE's Avatar
thanks....ill see if i can get to it this weekend....
Old Jun 14, 2015 | 02:57 PM
jayking232003's Avatar
hey all, I know this is an old thread but maybe, just maybe ya'll can help me! I need the little light fuse thing that goes in the awd push button switch. Does anyone know where I can get it?
Old Jun 14, 2015 | 05:31 PM
Gave you the part number and several places to check on this small indicator bulb on your other post on this. It is hard to find one now.
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
