buying a banshee
Old May 17, 2009 | 01:54 PM
pulldog500's Avatar
Default buying a banshee
Hey
I'm looking at buying a used banshee, 99 or newer. what are things I should look out for?,
what are the pros and cons to having a 2 stroke? does it have to be rebuilt often?
and should i stay away from buying a modded one?
thanks
Old May 17, 2009 | 07:43 PM
cody700's Avatar
Buying anything used is kind of a pig in a poke but you should be able to listen to it run and ride it and see if it is making any strange noises or if it is running good. I personally would shy away from a modded one. If I wanted a modded one I would have to be the one modding it. If it isn't done right it would be better with none.
Old May 17, 2009 | 08:11 PM
pulldog500's Avatar
Ok thanks a lot
Old May 17, 2009 | 08:56 PM
91Warrior357's Avatar
yea if its been bored wayyy over or has a 370 or 400 kit in it or something then it can be iffy, the motor work could have ben done by a retard, watch the pipes when they smoke and give it throttle make sure they smoke pretty evenly then once its shut off feel the cylinders and pipes for even temperatures, also check motor mounts for cracks and check a-arms and axle for bent spots or anything, check out the air filter to see if its ben tampered with or looks very dirty like someone didnt care for it, also make sure you get into it pretty good, shift up and down through all gears and that should help a little on deciding if its worth buying.
Old May 17, 2009 | 10:11 PM
Sidewinder500's Avatar
If money is tight in your situation, you might consider doing a compression test on it before you buy it, otherwise you might end up doing a top end rebuild in the very near future.
Old Jul 25, 2009 | 01:20 PM
superyfz350's Avatar
Find one with pipes. Pipes do the most for them and cost the most, so it might be a good idea to find one with them already on it. Stay away from drag ported, or bigger aftermarket cylinder banshee's because that means they were more than likely drag raced and abused.
Cole Hadden
Jun 15, 2025 09:05 AM
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
