2004.5 Sportsman 500 - Tach shows "0" rpm
Old May 22, 2009 | 04:24 PM
nickdryz's Avatar
Question 2004.5 Sportsman 500 - Tach shows "0" rpm
The battery on my wife's 2004.5 Sportsman 500 drained down over the winter. After charging it up to 13.97 volts, the tachometer reads "0" rpm. The battery reads 14.11 volts when the engine is revved up. The reverse speed limiter works, but the AWD engagement speed controller does not. All the other readings on the instrument cluster are okay, and the speedometer works fine. The lack of a tach reading is not a real problem, but I am concerned about the AWD engagement controller which supposedly works off the rpm. Any suggestions?
Old May 22, 2009 | 06:32 PM
chuck_raduenz's Avatar
sounds like a speedo issue. the awd system is controlled in the speedo.
Old May 23, 2009 | 07:41 AM
nickdryz's Avatar
Thanks, chuck_raduenz. I'll look into that first.
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
