01 arctic cat carb issue
Old May 23, 2009 | 10:04 AM
rossj1971's Avatar
Default 01 arctic cat carb issue
I got a 300 carb on a 250 (not my doing) the manual says I should have a mikuni bst31 well it runs with the Keihin CVK32 thats off the 300 but very rich so instead of me trying to figure out how to make the 300 work I decided I would just buy the right carb, so has anybody had any luck with the jc whitney carbs they show the one for my bike for 111 bucks, which is cheap compared to what the dealer wants I have went to several other sites but they were expensive to and I havent had any luck on ebay either..
Old May 24, 2009 | 08:42 PM
weez440's Avatar
if i was you i would just lean it out a lil. i think i go 2 1/2 turns out and it should put you in the ballpark. if you start running to lean it just won't run right and it will start missing.
Old May 24, 2009 | 09:19 PM
rossj1971's Avatar
thanks for that weez440 I am off work tomorrow and will give that a try. I decided against the jc whitney carb, I have found the right one on ebay just waiting if they except my bid, there asking 200 and i offered 150 thats as high as i will go, and i know if i buy it, the next day there will be the exact same thing for 50 bucks buy it now..lol. but I will try leaning it up a little to get me by till i get the right one..thanks..
Old May 24, 2009 | 10:13 PM
nkkiegem123's Avatar
yes, i also saw it in ebay..im looking forward to buy that
Old May 26, 2009 | 12:34 AM
swampyjunior's Avatar
According to my manual the Keihin CVK32 carb (used in both 250 and 300) setting for the fuel screw on an AC 250 is 1 3/4 turns out the AC 300 is 2 1/4 turns out. These are for a 2000-2003 AC machines.
So as Weez440 suggested I would try the 1 3/4 setting to lean the air/fuel mixture out. Also, check to make sure you do not have any air leaks around the intake where the carb hooks up or that can make the engine idle and run erratically.
Hope this helps.
SJ
Old Jun 6, 2009 | 02:33 PM
rossj1971's Avatar
Thanks SJ.
Jmuddin284
Jan 19, 2026 07:16 AM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
