Coolant Issues
Old May 24, 2009 | 11:19 PM
Chevra's Avatar
Default Coolant Issues
I have a 02 400 Sportsman and when it is warm out it shoots all of the coolant out. I don't understand why is does this because it was only 20 Celsius with a wind today. I was only driving down gravel roads and it just spits it out everywhere. What could be my problem?
Old May 25, 2009 | 04:22 AM
ZAKAZIM's Avatar
One make sure your rad is clean.....were is it leeking from. I had a 2000 sportsman that did this and it was coming out the vent hole on the overflow tank. After trying many things it endded up being the rad cap.
Old May 25, 2009 | 05:31 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
agreed onmaking sure the radiator is 100% clean on both front and back. you want to be able to see thur it. also make sure the therostat isnt stuck closed. how long does it take to overheat?
Old May 25, 2009 | 05:36 AM
trainfixerjer's Avatar
my 02 500 did the same thing when i found out my fan was not working.....check the fan also i would think...
Old May 25, 2009 | 07:42 PM
Chevra's Avatar
Ok I will check all those things out. It doesn't really seem to overheat, like the light doesn't come on or anything and it runs fine. I would say it was a good 5 hours before it happened this time. It happened one time but that was a super hot day. Im not exactly sure where is it spraying out of because it sprays it all over the place down there.
Old May 25, 2009 | 09:15 PM
upnort's Avatar
Does it spray out the top of the bottle on left side?
SDR-II
Sep 29, 2015 01:06 AM
Jenn1
Sep 8, 2015 09:16 AM
scram5050
Aug 19, 2015 02:19 AM
Coryco
Jul 6, 2015 07:30 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
