oil filter replacement?
Old May 26, 2009 | 11:41 AM
benji712's Avatar
Default oil filter replacement?
Any thoughts on how often to replace the paper oil filter in an 05 YFZ450 that's running synthetic 10w-40? I replace the oil every two days of riding (or ~10hrs). My guess would be about every 30 hrs (or on the 3rd oil change)?
I figure it should be about the same amount of ride time as any other quad.
Also any thoughts on using synthetic vs regular?
Old May 29, 2009 | 08:01 PM
cody700's Avatar
You are replacing synthetic oil after 2 days of riding? That is crazy IMO. You are throwing alot of money away for sure. I change my oil and filter at the same time and that is at 300 mile intervals using ordinary Valvoline ATV oil. Just for the record, I also feel that I am throwing good oil away changing at that interval. IMO if you are draining relatively clear oil out it probably is still good. You are riding a higher performance quad than I am so I am sure that your intervals should be a bit sooner, but 2 days seems too often. None of my business, but that is my opinion.
Old May 29, 2009 | 08:25 PM
webbl19's Avatar
I have heard that regular synthetic oils are bad for the friction plates on the wet clutch. Not really bad i guess but they make the clutch slip more.
Unless it is like motorcycle specific oil that is used with wet clutches.
Anyways i think you are changing your oil way to fast. I would say change the oil and filter maybe every 6 months. Checking the oil ever gas fill.
Old Jun 1, 2009 | 01:34 PM
benji712's Avatar
yeah thanks for the input guys. I thought that might be changing to often, i havent actually changed mine yet, was thinking about it, ive only been riding this quad for about 3 long days like 15 to 20 hrs. My last ride was a yz 250 2 stroke ( 1998) and my opinion on 2 stroke bikes that you ride hard should have frequent oil changes, just wasnt sure about the quad.
lightninboy
May 16, 2021 09:52 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
