Chain, sprocket question.
Old May 26, 2009 | 06:57 PM
Just-gittin-started's Avatar
Question Chain, sprocket question.
Im about to replace both sprockets and my chain on a 02 Raptor 660, I would like to make some adjustments to boost the low end torque, without sacrificing too much top end. I was wondering about which sprocket to add teeth to, or if I needed less teeth on one or both. I do mostly tight trail riding with some steep hills so the more bottom end torque the better. Any help would be great.
Old May 26, 2009 | 08:48 PM
91Warrior357's Avatar
go 1 tooth smaller on front sprocket and you should be good, it will be a little snappier after usin smaller front sprocket.
Old May 26, 2009 | 11:49 PM
hotblooded's Avatar
91 you hit it, 1 tooth on the front is same as three on the back and should be noticable. If not enough go 2, the nice thing with the front is there cheaper and if you do your chain right you prolly could use the same chain on both sprockets.
buddieboy
Dec 9, 2016 05:50 PM
mrtidy
Feb 3, 2016 05:00 PM
bigred20653
Oct 2, 2015 10:05 AM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
