1992 350L brake problem
Old May 29, 2009 | 03:09 PM
Tim631's Avatar
Default 1992 350L brake problem
I broke both bleaders off the orginal calipers. found replacement off a 2004 330. They bolted right on however I had to put in reducers at the line splitter . i can not get them to pressure up. I have blead them and i "think there is zero air". I even rebuilt the master cylinder. thank you for any help you can give.
Old May 29, 2009 | 03:46 PM
dooger's Avatar
Take your origional calipers and see if you can remove the old bleeder with an easy out. If you cannot, just drill them out and re-tap the hole for a larger bleeder. You can get new bleeders from napa for a couple dollars. I had to do the same thing on my '92 350L. New larger bleeders dont break off as easy either.
Old May 30, 2009 | 09:03 AM
Tim631's Avatar
Dooger, Thanks however I have easyouts broke off in both of them I forgot to put that in.
Reactant
Mar 30, 2022 02:08 AM
toonces
Oct 16, 2019 12:11 PM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
