400 big bear blowing fuse
Old Jun 2, 2009 | 09:04 AM
bullseye17's Avatar
Default 400 big bear blowing fuse
Have a 2wheel drive 400 big bear 02 that will blow the 10amp terminal fuse when you try to start it after it has warmed up for a while, I looked for bare wires and pulled both battery terminals and the frame ground and cleaned them all no luck. Also started unplugging one component at a time, like fan,lights ect,and tried to start but still didnt work.Have worked on alot of bikes and quads but this has been a challange any help would be greatly appriciated thanks steve.
Old Jun 2, 2009 | 09:24 PM
Kevin R.'s Avatar
Take the starter lead off and use a amp meter and see if it's drawing too many amps when cranked. It may have a bad starter winding or worn brushes.
Old Jun 2, 2009 | 10:50 PM
bullseye17's Avatar
Thanks Kevin will try it tomorrow.
Old Jun 7, 2009 | 01:11 PM
bullseye17's Avatar
Kevin I found the problem it was the ignition switch, was first time i have seen this problem befor,thanks Steve.
Old Jun 7, 2009 | 07:07 PM
Kevin R.'s Avatar
Glad to hear it was a simple fix.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
